AMP is dead quiet when I pull the amp
Postby Michel Bevan » Wed Nov 01, 2017 6:10 am
Hi,
I picked up a NAD 3020A amp. When I turn it on, a loud hum sound comes through the speakers for a second and then fades off. The problem is in the preamp section, as the amp is dead quiet when I pull the amp/preamp jumpers and turn it on. All of the pots have been cleaned. The amp works fine after the hum goes away. Someone suggest me the pre-out muting fets leak. J111 is generic so I looked here https://www.icrfq.com/part/2000795-J111.html for J111 and I got it here. I do not have a schematic for this unit. How many fets should I purchase, and where do they go?
Any suggestion will be appreciated.
Michel Bevan
Re: AMP is dead quiet when I pull the amp
Postby Daryl Kosinski » Fri Nov 03, 2017 8:51 am
I have retired from servicing industrial electronics for 39 years. With that said. Unless you understand the safe handling of static sensitive components (most are ) and have a static safe work area. Good soldering skills are also needed. leave the replacement of those components to the pros.
Daryl Kosinski
Postby David King » Mon Nov 06, 2017 2:29 am
Daryl's advice is good
You might have more luck at the music electronics forum but last I checked NAD made home audio equipment so you might have even better luck at a home audio electronics forum. MEF is here: http://music-electronics-forum.com/forum.php
Check out http://audiokarma.org/forums/index.php? ... ds.426532/
Postby Michel Bevan » Tue Nov 07, 2017 1:58 am
Thanks for sharing. It's a very nice information for me!
Michel Bevan
Postby Julius Miles » Sun Dec 31, 2017 6:55 pm
David King wrote:Daryl's advice is good
I have used MEF for a long time and can comment on how great some of the users there are. That place is a wealth of information.
Julius Miles
Return to Electronics
