by Greg Martin » Mon Jan 16, 2017 5:33 pm
Im going to wind some pickups as soon as it warms up,and would like to find some mini 3 or 5 pin connectors that would allow me to swap out test pickups with out repeated soldering during testing.i had though about deans connectors but maybe there are others??
Greg Martin
by David King » Tue Jan 17, 2017 1:14 am
EMG uses AMP connectors and those are widely available from places like Mouser and Digikey. I think you want the .1" pitch if you want to match up to the EMG's wiring harnesses. Other companies make more or less compatible connectors.
by Dan Smith » Tue Jan 17, 2017 8:05 pm
David King wrote:EMG uses AMP connectors and those are widely available from places like Mouser and Digikey. I think you want the .1" pitch if you want to match up to the EMG's wiring harnesses. Other companies make more or less compatible connectors.
Molex are good too.
Dan Smith
Return to Electronics
