Ibanez part
Ibanez part
Postby Cato Finsas » Thu Jan 12, 2017 7:24 am
Hi
Any body know where I can get hold of this part?
4PT00A0037
It is to a Ibanez PS120
Cato Finsas
Re: Ibanez part
Postby JC Whitney » Thu Jan 12, 2017 10:02 am
Hi Cato. Are you willing/able to fabricate the new one yourself? If so, look for pickguard stock at stewmac.com or any other place that sells guitar repair materials. Google search for videos on how to make a new truss rod cover. The shape of this one is tricky, but take your time. If you buy a sheet of pickguard material you'll have enough to experiment first and make a few mistakes. Carefully trace the old one onto your new material and then cut/file/sand it out to match. If the sides are beveled, you can do that with a small router bit if your skills and available tools are up to the task. If not, just take it slow and steady by hand. Make sure your new mounting holes are aligned just right, and you'll be in business. If you don't have the original to trace, use those photos, the existing hole locations, and a copy machine to make a pattern.
Whose signature is that?
JC Whitney
Re: Ibanez part
Postby Cato Finsas » Thu Jan 12, 2017 10:04 am
thanks - it is Paul Stanley`s signature.
Cato Finsas
Re: Ibanez part
Postby JC Whitney » Thu Jan 12, 2017 11:49 am
That explains the PS then, and I think that also means that coverplate is mirrored. That makes this even more fun. Maybe consider swapping out to an all black cover if you're not too concerned about keeping it "original"?
JC Whitney
Re: Ibanez part
Postby JC Whitney » Thu Jan 12, 2017 11:54 am
Ha! Turns out that guitarfetish and a bunch of other places sell mirrored acrylic pickguard stock. Who knew?
JC Whitney
Re: Ibanez part
Postby Cato Finsas » Thu Jan 12, 2017 12:08 pm
I want some
Cato Finsas
Re: Ibanez part
Postby David King » Sat Jan 14, 2017 5:06 pm
This place sells ibanez and a lot of other truss rod covers...
http://www.reproguitarparts.com/#!/Iban ... ry=1370956
Return to Electronics
