pickup bypass push pull wiring diagraham
Postby Greg Martin » Mon Dec 19, 2016 8:30 pm
hi I like to add a bypass push-pull switch to my fire birds bridge pickup does anyone have a tested diagram for this?? thanks
Greg Martin
Re: pickup bypass push pull wiring diagraham
Postby David King » Mon Dec 19, 2016 10:14 pm
A bypass switch can mean different things to different people. Are you wanting to cut one of the two coils in the bridge pickup to get a thinner, brighter single coil tone? Are you wanting to take the bridge pickup and it's pots out of the guitar circuit leaving just the neck pickup? Are you wanting to connect the bridge pickup directly to the output jack without it's volume and tone controls? Or are you hoping to do something else entirely?
Return to Electronics
