Debugging very low volume on new build
Postby Eric Baack » Thu Jul 28, 2016 12:19 am
So I wired up the fly inspired build and plugged it in for the first time tonight. It did not register on my tuner with it run straight in so I plugged into an amp and the sound was very quiet. I tried all positions on the selector switch with the same result. I have since put it to bed for the night but it has me thinking about the possible culprits.
There was a bit of crackle when turning the pots but I do not have the nuts on them tight yet so there might be a bit of an issue with some shielding contacting them from them moving a bit while being adjusted. I'm planning on checking the resistance on the pots in case one of them is bad but I'm done with it for the night. If that does not find the problem then I'll probably be tracking things with the multimeter and checking continuity at various points.
Any other ideas?
Thanks!
Eric Baack
Re: Debugging very low volume on new build
Postby Peter Wilcox » Thu Jul 28, 2016 1:29 am
First, with the ohmmeter, I'd check from all the ground connections to the ground lug on the output jack. Then check the pickup signal leads thru the pots/switch to the the tip on the jack. If necessary, connect the signal lead of each pickup in turn directly to the tip of the jack. If that doesn't work, you might post a wiring diagram.
Of course, before you do all this, try another cable. :)
Postby Peter Wilcox » Thu Jul 28, 2016 2:01 am
And make sure there are no short circuits from the signal path to ground except when volume pots are turned all the way down.
Postby Eric Baack » Thu Jul 28, 2016 8:33 am
Got low resistance on the volume pot. Looks like that is the culprit
Eric Baack
Postby Eric Baack » Thu Jul 28, 2016 4:29 pm
New pot fixed it :)
Eric Baack
Postby Peter Wilcox » Thu Jul 28, 2016 9:19 pm
Glad you got it fixed, but I've been through hundreds of new pots and never had a bad one. Used ones are another story.
Postby Eric Baack » Thu Jul 28, 2016 10:53 pm
I'm pretty sure that I wrecked the bad one. Was having trouble getting the middle lug soldered and probably had some get into it
Eric Baack
Postby Barry Daniels » Fri Jul 29, 2016 3:26 pm
Too much heat can quickly damage a pot, which can happen when soldering wires onto the case.
Return to Electronics
