archtop with volume only
Postby Greg Martin » Thu Oct 15, 2015 6:30 pm
I dont think Ive seen this question answered before,so --Im planning to have volume only on my next archtop build,but What if the next floating pickup I get sounds to bright or to dark?? Outside off returning pickups over and over, How can I fine tune/change the tone of the guitar? maybe different pot value? I don't know.
On this most recent build with tone control, we found the sweet spot with the tone at about 80 % rolled off and the pot was 500k and cap was .033 ???? thanks
Greg Martin
Re: archtop with volume only
Postby Daryl Kosinski » Thu Oct 15, 2015 9:16 pm
Easy, wire up the tone circuit, find the "sweet spot", measure the value of the pot, then replace the pot with a fixed resistor.
Daryl Kosinski
Postby Greg Martin » Fri Oct 16, 2015 7:02 pm
Hi I see what you are saying and have been pondering it all day. 1st the guitar is gone so testing its sweet spot cant happen.
knowing that the 500k pot was backed off to say 2 o clock would you guess a 200k resistor would be a place to start with the new pickup? would this resistor go in line with the pickup hot lead? or how would it be done? Also I was leaning toward a different pickup ,instead of the Armstrong slimbucker , a Bartolini 5J I want a more mellow tone the Armstrong on the new build. any thoughts?
Greg Martin
Postby Peter Wilcox » Fri Oct 16, 2015 7:23 pm
Yes, the resistor would go from the hot pickup lead (on the volume control) to one lead of the capacitor, with the other cap lead to ground. The potentiometer in a tone control circuit is acting only as a variable resistor (only 2 leads connected), and you should really first test wire one (a pot) in series with the cap to determine what value of resistance gives you the tone you are after - it will probably vary with different pickups, and maybe even from guitar to guitar with the same pickups.
You'll need a multimeter to do this - they're dirt cheap, even free with a coupon.
http://www.harborfreight.com/7-function ... 98025.html
You can't really tell the resistance from pot rotation, especially those with a non-linear taper.
Postby Eric Baack » Sat Oct 17, 2015 8:16 pm
Or you could put a linear pot inside the guitar and set it then forget it. Plus it is still there for pickup swaps.
Eric Baack
Postby Greg Martin » Tue Oct 20, 2015 7:50 pm
how about a mini lin trim pot? now would you maybe use a 1meg to allow for adjustment in a useable range??
Greg Martin
Postby Peter Wilcox » Tue Oct 20, 2015 8:35 pm
That would work - I'd use a multi-turn one to give you fine adjustment.
Postby Greg Martin » Tue Dec 01, 2015 3:56 pm
Also on next builds Id like a mini connector that would allow the removal of pickup and finger rest complete, with out un soldering. Ive seen some mini puter connectors but they are to fragile and seen deans plugs from my rc racing days, but there must be other options, any one found a good one? Got links?
Greg Martin
Postby David King » Tue Dec 01, 2015 5:24 pm
EMG and others have more or less standardized the connectors. Google will help you locate the correct AMP or Molex products from Mouser/Digikey
Postby Stephen Neal Saqui » Wed Dec 02, 2015 10:15 am
It's kinda nice to have a tone pot...give players their own options.
Stephen Neal Saqui
Postby Beate Ritzert » Sat Dec 05, 2015 7:53 pm
Greg Martin wrote:On this most recent build with tone control, we found the sweet spot with the tone at about 80 % rolled off and the pot was 500k and cap was .033 ???? thanks
In nearly any case You might need a 470k resistor in the place of the tone pot - the tone pot always contributes to the load of the pickup, and it will always damp its resonance peak.
Instead of also adding the cap You could just try a slightly smaller value of that load resistor.
Maybe it is useful to use a push-push pot (or a hidden mini switch pointing sideward if the circuitry is mounted to the pickguard)
for the volume control to make the additional circuitry switchable. Sometimes it might be useful to have a brighter tone at hand.
Beate Ritzert
Return to Electronics
