shatten thumb wheel bare ground wire question
Postby Greg Martin » Mon Jun 08, 2015 8:20 pm
hi Im using the shatten t2 thumbwheel controls and a production Armstrong floating pickup on this arch top build and need clarification on the bare ground wire placement.
The wire in the kit is 2 lead no bare wire unshielded. I want to use a shielded 2 lead with bare wire .will the bare wire twist with the neg pickup wire to the control tab, as well as the neg of the jack ? or do you leave one end of the bare un soldered and only solder the neg wire to the ground tab of the jack . There is no mention of shielded wiring or ground wire from Armstrong and I just plain forget ???
Greg Martin
Return to Electronics
