Resistance switch for HB coil cut
Jedi Clampett
Post by Jedi Clampett »
https://www.youtube.com/watch?v=7skVTzfkCcg
On this video Scott Grove shows a resistance switch that will switch to 250k from 500k so that when in coil switch mode the pu sounds more like what we expect from a single coil. He shows an old gibson S1 electric that has this feature. Now I am having trouble understanding what is going on and hope you can enlighten me. If a 500k pot goes from zero to 500k and pot is short for variable resister, why not just find out the 250k position and use that or less? Obviously I am missing something, hope someone can help. Around 7 min into video he explains and uses the resistance switching in a Gibson S1 as example.
Daryl Kosinski
Re: Resistance switch for HB coil cut
Post by Daryl Kosinski »
Potentiometers can be used as variable resistors or voltage dividers depends on the circuit. I didn't watch the video. I would need to see the circuit diagram to answer your question.
Jedi Clampett
Well, I know that, would love to see what the circuit
Eric Baack
Post by Eric Baack »
If your coil tap switch has a 500k resistor in parallel then it should emulate a 250k pot
resistance being calculated in parallel as
1/R1 + 1/R2 + 1/R3... = 1/Rtotal
Return to “Electronics”
