Pick ups for 12 string electric
Andrew Armstrong
Post by Andrew Armstrong »
Do 12 string electrics have different pick-ups to a 6 string electric. I'm thinking that the pole spacing may need to be a little wider. Appreciate any ideas.
Andrew
Rodger Knox
Re: Pick ups for 12 string electric
Post by Rodger Knox »
My Ric 360/12 has the same pickups as a 360/6, but the string spacing isn't much wider on the 12.
I think you could go wider at the nut, but keep a 2 1/8" to 2 1/4" string width at the bridge, and the pole spacing would be OK.
There's always the option of blade style polepieces.
There are "trem spaced" buckers that work with Fender's 2 3/16 strat bridges. They come in 49mm and 52mm generally.
Andrew Armstrong
Thanks for the replies. I did a bit of searching and I didn't come up with anything that suggests a 12 st electric needs special pups. I guess step 1 is get the bridge and then step 2 is see what the string spread is and how it lines up with pole spread.
AA
Pete Halliday
Post by Pete Halliday »
I don't know if you'll see this, but the TV Jones Super'Tron has a wide magnet which should work well with a 12. That's what I'm planning to use on one this winter.
John Kingma
Post by John Kingma »
Danelectro uses the same pickups for all their guitars - and basses, for that matter. I'm pretty happy with the sound of my Dano 12 string... And the pickups are long enough to accommodate just about any string spacing.
John Kingma,
Return to “Electronics”
